Old 27-Apr-2006, 17:23   #1
88 DB Limit at Assen guys.
According to the paperwork I have :
Max sound (static) 104 dba. ON FRIDAY 88DBA MAX (dynamic ) whatever that means.
Non compliance will result in exclusion without a refund!
Old 27-Apr-2006, 18:04   #2
glad I'm not going then.....
Old 27-Apr-2006, 18:12   #3
domski's Avatar
Maybe it's 104 when you're tested in the paddock, and 88 as you pass a sound meter on pit wall or something?
Just so you can't fit db killers for the test and then take them out before you go on track?
Maybe?
Old 27-Apr-2006, 18:35   #4
Mutters Mutters is offline
Mutters's Avatar
Mood: Don't tell them your name, Pike!
Aparently the trick is to suss out where the mic's are and if you go past with a few other bikes around you then you can nail it, but if you're on your own then back off as you pass the mic's.... ta daaa!
Wish i woz going @rse
Old 27-Apr-2006, 18:53   #5
Can't wait - the logistics and planning have been a right royal pain but I think it's all come together now
Old 28-Apr-2006, 16:21   #6
CK CK is offline
FWIW, ours make in usual race trim 96 & 97 respectively.
With std DB killers, they now both make...... 90
AK on the case this w/end
Old 28-Apr-2006, 16:39   #7
await the results then - and i'll take some thick socks!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:37.
