Old 29-Apr-2006, 17:23   #1
dst1 dst1 is offline
dst1's Avatar
Mood: thrash the bitch
916 running like crap
Just had my bodywork back from HC Race tech, so was so excited, but when I took the old girl out for a run its spitting and farting all over the place.
She ticks over fine but as soon as I put revs on her she is not HP....
As the tanks has been empty for a while could the filter catch all the crud as I have now filled up the tank again.
Any ideas guys and girls.....
Old 29-Apr-2006, 18:50   #2
Glyn Glyn is offline
Glyn's Avatar
Mood: st2......we can rebuild
sounds like a blocked up filter to me
Old 29-Apr-2006, 22:12   #3
dst1's Avatar
would a blocked filter cause it to run bad
Old 30-Apr-2006, 07:57   #4
sbwells sbwells is offline
sbwells's Avatar
Mood: Bring the noise!
Yeap
Have it replaced mate and chuck in a new set of plugs while at it
[Edited on 30-4-2006 by sbwells]
Old 30-Apr-2006, 09:50   #5
dst1's Avatar
Thanks lads......
Old 30-Apr-2006, 16:57   #6
pguenet pguenet is offline
Another thing that it could be is a split rubber pipe in the fuel pump. That happened to me last year and it took over a month to figure out the issue. You may want to check that the injectors are getting enough pressure.
p
Old 30-Apr-2006, 20:53   #7
dst1's Avatar
Well I am a knob, fitted the new filter but due to my lack of brains I forgot to buy a new o ring for the mounting plate.
Used the old one a fuel ****ed all over the bike and the garage floor.
Wife went mad and the whole house stinks of petrol.....
Will have to wait untill tuesday to order a new one, I do feel a right plonker rodney
Old 30-Apr-2006, 22:16   #8
zhed44 zhed44 is offline
zhed44's Avatar
Mood: YELLOW!!!
i did the same job last week and used the old sealing ring and i seem to have got away with it.
are you sure that you haven't just trapped it or something as they are (as i was warned) a bit tricky to get back in. i got mine seated square by lining the plate up in the hole and then clamping it down very progressively (half a turn on each bolt in turn) using 3 longer bolts, although i had to guide the ring in gently with my finger on one side of the plate.
this worked for me, but if i were you, before trying this method i'd wait for it to be OK'd by one of the more experienced guys on here as it was the first time i've ever done the job.
Old 01-May-2006, 20:53   #9
dst1's Avatar
The o ring was so loose it just kept falling off, as soon as I turned the mounting plate over the ring would fall off.
I think the petrol over the years has just mullered it.
I will play safe and get a new one.
Old 01-May-2006, 20:57   #10
Get a new one and use vaseline to ensure it slips in
