Old 02-May-2006, 06:58   #1
kiwigreg kiwigreg is offline
851SPTC ??
I have recently bought a 1990 851, and the Cagiva paperwork stated that this bike is an 851 SPTC, what does the TC stand for??? I gather that the SP means Sport Production?, can you experienced knowledgable people help me out. It also has low mounted mufflers and was sporting a dual seat when I got it! Thanks in advance, Kiwigreg
Old 02-May-2006, 08:34   #2
Nattyboy Nattyboy is offline
Nattyboy's Avatar
Mood: Back down to 3 :>(
Not sure about the TC bit...but early SP's had low slung exhausts. If you ring DUK with the chassis number they should be able to give you a steer.
Will get your new mudguard off today Greg..
Nat
Old 02-May-2006, 10:33   #3
phil911 phil911 is offline
phil911's Avatar
Mood: Privileged ...
I've been told :
Track Conversion for special markets ...
What about the VIN ???
Phil911
Old 02-May-2006, 11:31   #4
weeveetwin's Avatar
Hi Greg
The SP2/3/4 and 5 were all 888 cc. If it was an SP2 (1990), the chassis number would confirm this, ie; ZDM888S*****. The 851Strada was numbered ***851S****.
The 888cc SP2 did have low mounted mufflers, but it came (as did all SP models) with an aluminium subframe beneath the seat, and this wouldn't support a dual-seat. It also had Ohlins suspension front and rear, and a silver plaque on the top yoke bearing its production number.
Maybe Phil911 has hit on the right answer to the 'TC' initials. (The only other 'TC' 851 was the early 'Tri-Colore' - but I don't know if this would be recorded on the docs).
Steve
Old 02-May-2006, 11:32   #5
I wrote to Ducati with the Vin# and engine number and they also said "Referring to your request we kindly invite you to send us pictures of the bike:
- Headlight
- Fuel tank
- Engine
-Side bike picture
this will be helpful for us." and that was after I supplied that info so,.....................
Vin#ZDM1HB6P1LB001362
engine #001419
any help in deciphering this info??
Thanks as always,
Kiwigreg
Old 02-May-2006, 12:23   #6
Ains. Ains. is offline
Ains.'s Avatar
Mood: He's not happy {:o( He's back at sea!
Is it this one?
If so, looks like a normal 851 Strada to me.
Ains.
[Edited on 2-5-2006 by Ains.]
Old 04-May-2006, 10:43   #7
phil911's Avatar
Kiwigreg,
The following doc. should be helpful ...
Phil911
Old 04-May-2006, 11:51   #8
NUx NUx is offline
NUx's Avatar
It is indeed possible that Phil is correct.
Because did you all know that the 888 SP(4)S is not the only special edition of the SP version?
A friend of mine has a 851 SP(2)S. The difference with a normal SP?
Well, the engine is more corsa than the standard SP2 engine and it has also a nr, like the bike. So the bike has a nr and the engine has his own nr. Also a very nice bike
[Edited on 4-5-2006 by NUx]
Old 05-May-2006, 05:55   #9
you mean the engine has its own number? also, where is the identifying number on the ECu box(P7?-P8?), apparently, not under the lid!
Is it on the bottom
Bike is currently in friends garage, I was over yesterday and took detailed pictures to send to Ducati and they said that they will verify its identity, we shall go from there!
Thank you to all who have taken the time to comment, ..............interesting though that with all the knowledge present here, that a model ID can still be a very difficult decifering issue with these type of motorcycles,
Kiwigreg
Old 06-May-2006, 07:51   #10
loony888 loony888 is offline
Mood: sensational!!
if it's a 1990 model it should have a P7, the P8 ECU was fitted to the 888 93 model and the early ones of those (first 500 i think) still had a P7.
