Old 02-May-2006, 09:49   #1
Dave G Dave G is offline
Dave G's Avatar
Specs of ss forks?
Can anyone tell me whether a set of forks from a 98 injected 900ss(with 65mm caliper mounts) are fully adjustable?,or only for preload?
Thought I'd ask here as I'll get a quicker answer.
I'm sure I have a site that gives me all this information for all models and years but can I find it when I need it?
Old 02-May-2006, 10:13   #2
Not sure but...
http://www.duc.nu/manuals/
Old 02-May-2006, 10:17   #3
Hmmmm...year 2000 ss:
Suspensions
Front
Hydraulic upside-down fork.
The front fork used on the 900 models features outer
adjusters for rebound, compression, and preload (for
inner springs of fork legs).
Stanchion diameter mm:
43 mm/1.69 in.
Travel along leg axis:
120 mm/5.12 in.
Old 02-May-2006, 12:11   #4
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
Depends which spec' SS.
Yes and no. Some came with fully adjustable Showa froks - compression, rebound and preload. Some came with totally non-adjustable Showa or Marzocchi. I have 3 800ss bike...2 with and 1 without. I've seen 900's with the same.
Old 02-May-2006, 12:31   #5
ali ali is offline
ali's Avatar
Mood: Damp
The only time I've seen 900s with non-adjustable is on US spec 900 Sports, not Supersports. They also came with steel swingarms and sachs rear shock rather than showa. I've never heard of a uk 900 with this spec but you never know, the factory are famous for using what's available at the time!
Cheers,
ali
Old 02-May-2006, 12:36   #6
I've seen two UK 900's of recent with non-adjustable forks. I can't say whether or not they were imports but, they were 2004 bikes...and this is when I thought the last of the 900's had Ohlins and 5-spoke wheels...probably more down to the vagaries of the factory I think
Old 02-May-2006, 14:06   #7
I had a '99 900ss(ie) with fully adjustable Showas. As far as I knew all the inj. 900ss's had these, and the 900 Sport and Darks had lower spec suspension (don't know exactly what though).
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:47.
