Old 21-May-2003, 18:22   #1
Bianchi Bianchi is offline
TecMoto air filter
Am abt to fit their under tank ITG air filter - any tips/problems I shud look out for?
Would it be a good idea to remove the rubber restrictors in the ram air tunnels?
TIA
Old 21-May-2003, 18:37   #2
Don't know if they supply the filter with any filter oil, but it's worth oiling the filter before fitting.
I use PJ1 filter oil on mine. Very messy, but worth doing so all the dust gets caught.
Remove the rubber bungs.......and the original filters to
I find fitting the thing easiest if you put your hand inside the rearmost hole and work the front hole over the bellmouth from the inside. Fitting the rear is easy enough from the outside of the filter.
Old 22-May-2003, 11:14   #3
Nelly,
Many thanks for your input.....
Old 22-May-2003, 22:30   #4
stoddy stoddy is offline
Mood: Got that track day bug real bad
Get some one to give you a hand to tack the fuel tank off, as the connections under side are a sod with one hand holding the tank.
Also try to do it with an empty tank, much more easy.
Old 22-May-2003, 23:05   #5
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
What you want to do is put your hand inside the rear opening and the push the filter over the front bell mouth. The rear bell mouth is a lot easier to engage than the front.
Old 23-May-2003, 19:56   #6
Thnx guys - did all your suggestions, and it went like clockwork.
Not often that happens eh.....
Cheers again
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:16.
