Old 03-May-2006, 09:13   #1
Tonio600 Tonio600 is offline
Tonio600's Avatar
Mood: What a wonderful world.
Raising the rear height on the old Monster frames...
Can I do it using the standard bolts between the arc and the swinging arm? Will that be enough for a race bike?
Anybody near Dorking has got spare banjo bolts?
Bike is noooooooooooooooooot ready...
Old 03-May-2006, 09:18   #2
There are spacers for the 888 (same hoop I think) that screw into the bottom of the hoop and then the rose joints screw into the spacers. Lift the back end by about 20mm I think.
You come across them on eBay - try an eBay search on 851 and 888
Old 03-May-2006, 09:23   #3
Tonio600's Avatar
Cheers Jools, will have a look at that
Old 03-May-2006, 09:29   #4
multi600 multi600 is offline
multi600's Avatar
Mood: Hopefull
Paul #4 welded an extra section into his to give more height.
Mike
Old 03-May-2006, 10:11   #5
Mines having a bit welded onto a new hoop as my rose joints are screwed out far enough already.
Old 03-May-2006, 13:18   #6
hawk hawk is offline
hawk's Avatar
Tonio
rich @ louigi does the rear kit that gets put on ebay!!!!!!
basically screw in spacers on top of rose joints
give him a call a.s.a.p on 07775 557797 as he's soon leaving for assen
had a few in stock last time i was down there
Old 03-May-2006, 13:29   #7
phil_h phil_h is offline
phil_h's Avatar
I've got rich's spacers on the beast (well he did build it)
They are really easy to fit, the only down side is that they are about 25mm long so they give quite a step up in ride height from standard with no adjustment inbetween
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:36.
