Old 06-May-2006, 18:02   #1
jj250 jj250 is offline
jj250's Avatar
748 ride height-- a rough guide?
can anyone suggest the rear ride height for my 748 and also a simple way to measure it ( i dont have any special tools), ive changed sprockets etc and it now feels lower, any info appreciated...cheers
Old 06-May-2006, 18:09   #2
After that have you got the wheel hub in the right location?
Old 06-May-2006, 18:10   #3
As its eccentric you need to make sure first of all that the spindle is in the lower half of the hub.....and ideally, around 5 0 clock as you look at it from the sprocket side!
Old 06-May-2006, 18:27   #4
jj250's Avatar
call me dumb but i cant see how you can check it from the sprocket side, however from the wheel side it appears to be at 7 o'clock which if reversed would be 5o'clock?
Old 06-May-2006, 19:54   #5
Jasper Jasper is offline
Jasper's Avatar
this is how to view it.
Old 06-May-2006, 20:10   #6
Er,,,,,your dumb!
Once youve sussed it ot you will be able to see it from any position!
youve only got to look at where the centre hole is sitting!
that piccie is good.
Old 06-May-2006, 23:40   #7
smilo006 smilo006 is offline
smilo006's Avatar
Mood: I like my bike
try this......
http://www.section8superbike.com/748...suspension.php
Old 06-May-2006, 23:42   #8
or drop harv748 a line, he sells a great measuring tool
Old 07-May-2006, 08:51   #9
zhed44 zhed44 is offline
zhed44's Avatar
Mood: YELLOW!!!
Originally posted by smilo006
try this......
that was a really good article right up until the last paragraph.
Stage Three
1. Buy a Magnesium arm and a set of triple clamps with 27mm of offset. About $3000 on a good day.
Old 07-May-2006, 16:57   #10
jj250's Avatar
well without taking the carrier off it looks like its at about 6ish, basically i know it was right but ive just swopped the 40 on the back for a 38, and apparently each tooth equates to approx 3mm drop in height?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:13.
