Old 08-May-2006, 22:32   #1
chrisw chrisw is offline
Bikes: 999 Mono/1198S
chrisw's Avatar
999 Coolant filling
After my coolant hose mishap on the IOM I intend to do a proper repair when I am off this Thursday. When I had the fairing off I saw that the radiator links to a black expansion bottle on the front right hand side. Should this be full of coolant or empty? Mine is actually empty. The radiator was fullish when checked at the radiator cap.
Old 08-May-2006, 22:39   #2
duc daz duc daz is offline
duc daz's Avatar
if you look in your manual it will tell you to have the coolant between the two lines on the bottle /when engine is cold
Old 08-May-2006, 22:40   #3
tricky tricky is offline
Mood: Need spares
If you look at the little tank from the left hand side of the bike you will see it has some level markers on it. The coolant should be between the 2 markers.
Its a bit awkward to see, you sort of have to stick your head under the head light enclosure then look by the fork leg.
Old 08-May-2006, 22:48   #4
chrisw's Avatar
Cheers guys
Old 08-May-2006, 22:50   #5
Carbon749's Avatar
Mood: I own a flame thrower
Pain to see, use a torch or inspection light to help.
Fill the system via the rad' filler cap and then top up the expansion bottle so that the coolant is between the lines.
Take it for a good run at normal running temp and then check the level in the bottle.
Old 09-May-2006, 19:10   #6
chrisw's Avatar
All fixed. Thanks for the info guys.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:10.
