Old 10-May-2006, 11:45   #1
DP DP is offline
DP's Avatar
Mood: Splodge ness abounds
Race pattern Gears change advice please
I need to change my Bostrom 998s to a race pattern gear change as I get confused whilst riding and racing.
Last night I changed the thing that connects to the gearbox to the gear lever so it is now pointing upwards and is away from the engine casing, instead of near the engine casing aand below the connector.
It seems to work but the lever doesn't always spring back quickly when used.
Am I causing a problem or is this a safe change to make? do I need to check anything or make more ajustments?
Thanks in anticipation
DP
Old 10-May-2006, 12:01   #2
Monty's Avatar
DP do a race pattern lever-as does JHP. It's a simple lever that goes straight on the gearshaft and replaces the pivot and rod and original lever. This will give you a much more positive gearchange. Setting it up as you have will work but the gearchange linkage is working through pretty extreme angles so will be stiffer and may bind.
John
Old 10-May-2006, 12:11   #3
Lily Lily is offline
Mood: stiff and tired
I have just done exactly this on a Bostrom as Monty has described.
Lever is about £100 though
Old 10-May-2006, 12:13   #4
DP DP is offline
DP's Avatar
Looks like a call to JHP then
thanks to you both
DP
Old 10-May-2006, 17:34   #5
logyk logyk is offline
logyk's Avatar
Mood: Relaxed - don't worry about things you can't change
Try ebay.de.
I got one for about £45 which works perfectly !
Old 10-May-2006, 17:41   #6
Yeah and I'm still waiting.... ££££
Old 10-May-2006, 17:52   #7
Totto Totto is offline
I have one , poss for sale U2 me with an offer , i got mine from Tec moto a while ago , but its the same a Jhp one , if you dont like it send it back !
U2 or ring me 07834861340
[Edited on 10-5-2006 by Totto]
Old 10-May-2006, 18:26   #8
butch890 butch890 is offline
Mood: Enjoying Togdom !
Dave,its easy when you use an 05 monster splined lever on the gear change shaft,costs a tenner job done ,i have a spare give me a ring and its yours.
Butch
Old 10-May-2006, 18:43   #9
Butch
Butch can you clarify an 05 monster lever fits on to the gearbox splines and it costs a tenner........ill give that a go......!
Old 10-May-2006, 18:57   #10
DP DP is offline
DP's Avatar
Cheers all now sorted. Hope you like The Avatar Butch,
And hows the Shoulder?
DP
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 02:17.
