Old 10-May-2006, 22:22   #1
Lee999s Lee999s is offline
Mood: good
Gearing
Hello everone, this is my first post and was wondering if anyone new where i can get a 14 tooth front sproket for my 999s??? iv been told by a reliable source that this will help the power curve in addition to a power commander.
Old 10-May-2006, 23:40   #2
Hmm,cant see how a new sprocket will help the power curve,...but anyway,try B&C.Just over £20 for a 14 toother.
http://www.bandcexpress.co.uk/cgi-bi...OAD&nav=Ducati
Old 10-May-2006, 23:51   #3
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
I wouldn't advise putting on a small sprocket like this because they give the chain a hard time. Go up two teeth on the rear sprocket instead.
Old 11-May-2006, 20:42   #4
Mood: good
I'v been told a 14 tooth on the front is the same as going up 2 on the rear???
Old 11-May-2006, 21:02   #5
generaly, one down on the front equals 3 & a bit up on the back.
Chris.
[Edited on 11-5-2006 by chris.p]
Old 11-May-2006, 21:06   #6
the numbers are correct, but if you have a 999s......i think the power what 136+ horses, putting a smaller sprocket on the front makes the chain run around a tighter radius.......much beter to go up on the rear.......sprockets are same price...ish, treat yourself to a new gold chain so it could be a bit longer!!!
Old 11-May-2006, 22:34   #7
nathanhu nathanhu is offline
nathanhu's Avatar
Mood: head down
im runnning a 38t on the back of my 999
if you have a old style swingarm you can fit 38t without adding a link but if youve got the new swingarm youll need to add one
ive done both and find the rear sprocket is friendlier to the chain requiring less adjustment
Old 12-May-2006, 22:17   #8
Mood: good
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:06.
