Old 12-May-2006, 00:36   #1
900MAN 900MAN is offline
900MAN's Avatar
Mood: 900 went 999 gone, Multi came and went, 749 Nero now
Hot Disc
My rear disc is trying to be a griddle.
After a brief 5 minute ride with pretty much only front brake action, the front discs were barely warm whilst the rear was sizzling.
It has been squealing a bit at low speeds but doesn't look worn.
Change the pads?, or is there more than meets my new(to this bike) eyes
Old 12-May-2006, 00:44   #2
ericthered40's Avatar
Mood: renegade sexy racer
Might be best to take the caliper off and give it a clean first, cheque out the pads wile your at it.
Old 12-May-2006, 05:43   #3
Sounds like the pads are rubbing on the disc and not returning when the pressure is released.
As Eric said,whip the caliper off and clean it up.Smear a little Coppaslip grease on the back of the pads.
Old 12-May-2006, 10:48   #4
Also, check the pedal adjustment. Dunno about 999's but on my ST I had similar symptoms when my brake pedal was adjusted too far so that it didn't let the fluid back into the master cylinder quickly enough.
Old 12-May-2006, 11:55   #5
900MAN's Avatar
Thanks guys.
Old 12-May-2006, 21:52   #6
duc daz duc daz is offline
duc daz's Avatar
best put brake grease on the back of the pads not copper slip you dont want that stuff eating at your piston seals
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:41.
