Old 12-May-2006, 23:58   #1
moozaad moozaad is offline
Bikes: Ducati ST2
Mood: Fruity
15 / 43 sprockets
recommended for an ST2?
I think I have the smaller 14t front and standard rear sprocket on at the moment but find it noisy and 'whines' alot. So I want to change it but keep that little extra power!
Old 13-May-2006, 00:01   #2
andys 900ss's Avatar
Try a 45 on the rear with the 15 front.
My ss dont whine, it THUMPS!! Cant here anything over the cans and clutch.
Andy
Old 13-May-2006, 01:07   #3
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
ST2 standard is 15/42, ST4 is 15/43 and ST4S is 15/38
I run 15/43 on the 4S and it's great.....
As Andy suggests, up a bit on the rear would help with a 15 front... you'll find that the whine is the chain rubbing on the upper chain buffer on the top side of the swingarm at the pivot end.
It gets worse if you add a bit of ride height too.
The 15 tooth front should get rid of the problem for you.
Old 13-May-2006, 11:02   #4
Bikes: Ducati ST2
Mood: Fruity
So to confirm Andy's idea: 15/45 is a good idea? Will that work with a standard length chain?
