Old 13-May-2006, 21:00   #1
chunda chunda is offline
Mood: desperately seeking ...summer
non starter - any ideas?
He guys
Well don't know what's going on. Went to start the 749 after its monster layoff and... nothing. Charged battery in, dash lights up as it should and lights go out but neutral light goes out as well leaving just the oil light on. And the bike is in neutral. Checked the fuses - ok. Also can't remember back that far but can you not hear the fuel pump make a buzzing noise - 'cos it ain't now! Any clues would be happily received!!
H
Old 13-May-2006, 21:08   #2
Ducati Dealer
wilf's Avatar
The electronics may not let the bike start if its not in neutral (of if it thinks it isn't in neutral)
Check its not in a false neutral (can be between 3rd and 4th)
or
The neutral light switch may have got stuck, if you put it into gear (you may have to roll the bike back and forward a bit to get it in) then it may click it back into life.
when the neutral light then comes on, the fuel pump should prime and your off!
good luck.
Old 13-May-2006, 21:13   #3
Yeah that makes sense, I was thinking it must be something to do with neutral. Have been up and down the box a few times without seeing neutral but will try rolling it in gear - thanks!
Old 13-May-2006, 22:08   #4
bolds bolds is offline
Are you getting the orange engine management light coming on?
Old 13-May-2006, 22:09   #5
Could just be the connection on the neutral light switch in the back of the gear box.Had trouble starting my Multi and found the connection was loose.
Try starting the bike with the clutch lever pulled in.
Old 14-May-2006, 17:01   #6
Thanks for your suggestions and spot on to KeefyB - the neutral wire was loose! Does not seem to really go in well at all. Never mind all is good now...
Old 15-May-2006, 05:57   #7
Yep just a crappy push on connection.A bit awkward to get at too.
Glad you have it sorted.
Old 16-May-2006, 11:05   #8
bike mad bike mad is offline
bike mad's Avatar
keefy 10/10
keep up the good work
