Old 14-May-2006, 15:31   #1
Tonio600 Tonio600 is offline
Tonio600's Avatar
Mood: What a wonderful world.
Carbs cleaning and bad surprise
I miss riding on the road too much, so today I started to service my 600M myself (please don't laugh), hoping to put it back on the road in the next few weeks.
So I started by cleaning the carbs, went almost well until I noticed that one of the 2 "membrane" (sorry don't know the name in English) was cut in one place (see attached pix). Do I need to replace it (I would think so but have no idea of what it does... so maybe that's not that important). If so what's the cheapest way to source one?
Thanks in advance for your help. When the carbs are cleaned and fitted on the bike, then I'll change the belts. Lots of fun to come
(Dr AK, I hope you didn't plan some holiday at the other end of the world next week )
Old 14-May-2006, 15:51   #2
Tonio600's Avatar
bugger, here is the attachment.
Old 14-May-2006, 15:59   #3
domski's Avatar
It's called a diaphram. It looks a bit fooked too
You defo will need to replace that, coz it acts as a seal (sort of thing) so even a pin hole would mean it wouldn't work properly.
D'oh!!
Old 14-May-2006, 16:40   #4
Murray Mint's Avatar
You will have to replace the diaphragm as this is a very important part of the fuel system. The diaphragm lifts the main needle valve by the suction caused when opening the butterfly valve in the air intake.
Old 14-May-2006, 17:47   #5
Tonio600's Avatar
Cheers guys
Let's try fo find one...
Old 14-May-2006, 18:07   #6
Dougducati Dougducati is offline
Mood: Got a life and have no agenda!!
Aaaaahhh!! Brings back nightmares for me. This part perished on my M600 too but on the ride home from Rugby. It ended up riding like it had really bad turbo lag. Nothing nothing nothing waaaaaaa!!! You can live with this when there is no traffic around but when you are close behind a carit can be a bit scary!!!
Took ages forme to get replacements but that was because it was August and Italy was shut. But I'm sure there are enough people here that can help you find spares. Check the other one too because even a slight crack in the rubber will mean things don't work properly.
Good luck,
Doug
Old 14-May-2006, 18:11   #7
Tonio600's Avatar
Cheers mate.
it seems the other one is fine. I don't know where I read that most of the time it happens to the front carb (I mean the carb linked to the front barrel).
Old 18-May-2006, 13:49   #8
Derek Derek is offline
Bikes: ST4s ABS
Derek's Avatar
Yamaha TDM/TRX850 uses the same carb. You might be able to get one easier from a Yamaha dealer.
Old 22-May-2006, 01:11   #9
Tonio600's Avatar
Allen's Performance are the guys to call
