Old 14-May-2006, 16:35   #1
soholush soholush is offline
Mood: jovial
Sport 1000 baffles.... help!
Does anybody know how i'm supposed to remove the baffles on the twin termis for my sport 1000?
I used an allen key and all it did was round the heads off, they appear to be made of cheap soft metal.
Old 14-May-2006, 23:37   #2
guest1 guest1 is offline
We watched the mechanic in Woods take the baffles out in less than 5 minutes.
Allen key (right size) then pair of pliers to pull them out.
No more than that. If you've rounded the 'heads' then I guess you'll either have to drill them out or force a slightly larger torx driver in them and hope for the best.
Old 15-May-2006, 23:33   #3
Mood: jovial
damn, i did use the correct key - went out and bought one. A guy in a dealers said they had a spot weld in them. so, where do i need to drill? is the next question.
i need to liberate the sound of that lovely motor.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:21.
