General Motorcycles only
Old 15-May-2006, 13:53   #1
loverobot's Avatar
fzr600 on brink of death lol
after caning one of my fzr600s for four solid days in blistering temps in spain i have the following probs -
white smoke out of exhaust when cold and when warm but revved hard
blackish fluid dripping from the exhaust join where the can meets the downpipes - seems only when cold
losing oil - quite quickly
i am thinking
rings
valves
maybe a fuelling prob
what do i need to look at, in what order and will i need to remove the engine from the frame?
i have another engine i could put in but it is from a race bike and currently has no starter clutch so would need to swap that over
also the 'oily' bike cost me £300!! so i dont want to lob loads of cash at it
thanks
Old 15-May-2006, 18:20   #2
White smoke in the exhaust is coolant, oil would make blueish smoke. So perhaps head gasket has gone. You say its using a lot of oil though..
Old 15-May-2006, 18:48   #3
Shoot it, replace with Ducati.
HTH
Old 15-May-2006, 18:56   #4
Glyn Glyn is offline
Glyn's Avatar
Mood: st2......we can rebuild
sounds like head gasket
Old 15-May-2006, 20:01   #5
compression check, then again after squirting a bit of oil down the plug ole.........
Old 16-May-2006, 08:03   #6
loverobot's Avatar
what would the oil down the plug hole do andy / tell me?
head gasket - not thought about coolant - will check it out!
Old 16-May-2006, 09:39   #7
Do a compression test. Squirt some oil in and do it again. If the reading goes up then its a rings problem, if it doesn't then its a valve or other problem.
Old 16-May-2006, 09:47   #8
loverobot's Avatar
excellent
cheers
i am thinking rings - if head gasket that would be cool
if rings the engine gets binned !
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:31.
