Old 17-May-2006, 15:05   #1
desmobob desmobob is offline
desmobob's Avatar
Mood: Beige.....
999R F04 nose fit an F05 ?
I'm sure I posted this earlier, but it's gone 'walkabouts' - my ISA log's even say it was posted.......
Anyone know if a 999R F05 (single pair front air intakes) - nose will fit an F04 (air intakes and air defusers) 999R and support the F04 999R side panels ?
Old 17-May-2006, 15:17   #2
F04 and F05???? Factory bikes as in race bikes? They'll use the pierobon bracket and it's a nosecone and sides with a seperate belly pan.
Or do you mean MY04 and MY05 "road" bikes? if so yes as far as I am aware it's merely cosmetic for the R model, the R model also came with slightly wider nosecone over the other models, but all models from 05 onwards had the same width.
The easy answer is yes in theory
Old 17-May-2006, 15:32   #3
desmobob's Avatar
Mood: Beige.....
Sorry, I meant the 'homolgation 999R MY04 - MY05 models'
So as long as the nose cone is from an 'R' model then it will fit.
Thanks heaps.
Old 17-May-2006, 16:00   #4
The Big Red One The Big Red One is offline
Mood: Sparks will fly. If it keeps on
No The r is wide 05 then the 04 and the backets are diffrent i tried. To bad. Hope that saved you some money.
Old 17-May-2006, 16:36   #5
I understood all R models are the wide fairing.......................its just whether they are vented ot not.
Old 17-May-2006, 16:49   #6
All R's had wider nosecones than the other models until 05 when all models were the same as the R.
The 04 model had carbon brackets to mount the nosecone to, whereas I think 05/06 models have magnesium brackets that was the major difference and also affected the nosecone width
Old 17-May-2006, 17:13   #7
desmobob's Avatar
Mood: Beige.....
Mine has magnesium mounting brackets, I understood all "R" models did. I'll check with JHP before I go bidding
Old 17-May-2006, 19:22   #8
Fila on the e bay see you there. Hope you get the lot as i will be playing too. We could have one side each.
Old 17-May-2006, 20:28   #9
Not Ducati items so i just found out. Top fairing not Ducati item rear end not Ducati item. The R was a damage insurance job, done up then couldn't sell the thing. So broke it. I a mate said it been around for ages. On here somewhere with the damage before and after.
[Edited on 17-5-2006 by The Big Red One]
Old 17-May-2006, 21:17   #10
best laugh i have had in ages some won the top fairing so else the one side have to go see who wins the other bits. Take a look
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:19.
