Old 17-May-2006, 18:54   #1
Trig Trig is offline
Bikes: Ducati 999, BSA A65 Lightning, Matchless G80s
Trig's Avatar
Mood: Fed up with DIY!
C Spanner
Please can anyone give me the details of a C spanner that will make adjustment of the pre-load on the rear shock easy?
Thanks.
Old 17-May-2006, 18:57   #2
khushy khushy is offline
khushy's Avatar
LOL!!!
You need to take the shock out to adjust the pre-load as its too tight to get to in-situ.
Not impossible to take out without removing the exhaust, but VERY fiddly - I am going to remove mine next month and add the hydaulic perload adjuster (c£100) to make in-situ life easy.
The C Spanner - should be in your toolkit.
Khushy
Old 17-May-2006, 19:06   #3
bike mad bike mad is offline
bike mad's Avatar
do you have a web site for the hydaulic perload adjuster,
it sounds a good ider
Old 17-May-2006, 19:18   #4
khushy's Avatar
its a standard Ohlins item - maybe www.ohlins.com??
Old 17-May-2006, 19:20   #5
khushy's Avatar
a picture
here you go!
Old 17-May-2006, 19:31   #6
Gizmo Gizmo is offline
Mood: is it the weekend yet??
you can get a thin c spanner from Harris performance, its the genuine Ohlins one and ain't too badly priced, get 2 and you can lever against each other to loosen the top nut and it is possible to adjust pre-load with them but be prepared for scraped kuckles. I haven't bothered with the hydo unit, its expensive and heavy its only 4 bolts to drop the shock out so easy to do if you do feel the need to mess about with it. I have an extra heavier spring just in case I convert to bip rather than using preload, it don't take long to do. Using the hydro means you need a spring compressor to swap springs as well
Old 17-May-2006, 20:31   #7
Lol, there's progress for you - taking the shock out to adjust it!!
Old 17-May-2006, 23:10   #8
900MAN 900MAN is offline
900MAN's Avatar
Mood: 900 went 999 gone, Multi came and went, 749 Nero now
Cant I just use a hammer and drift?
Old 17-May-2006, 23:56   #9
Trig's Avatar
Yes Steve I am sure you can but if someone knows a better way then i am all ears
It is a Showa on my bike so presumably Ohlins tools won't work and I didn't get a C spanner for the shock in the tool kit.
I really don't want to take the shock out. Antony what was the spanner that Mark was talking about? I have seen the type that suit various sizes but I think he was talking about something different.
Old 18-May-2006, 09:46   #10
I think the ohlins tool does work with a showa, the coil spring OD is the same so the chances are the top nuts are similar, I'll check when Dseered brings his bike up on Sunday but I'm sure I used those spanners to set his up.
you can get adjustable c spanners but they'll be big, try M and P or Busters, the ohlins one is the thinnest and slimmest I could find and for the price you could always hacksaw a bit off the end if its too long. I'll let you know on Monday if it fits.
Or give K tech a call, they are the Showa importer and might have a similar spanner....
