Old 17-May-2006, 22:11   #1
Animal Animal is offline
Animal's Avatar
Clutch pack needed urgently
Where's the best place to buy a clutch pack for a Surflex slipper?
I presume I need a pack, the clutch has started slipping badly in the last day. Any other thoughts?
Old 17-May-2006, 22:13   #2
Dibble
is it a standard 12 tooth basket ? if so just call Nelly (see sig) ... if its a 48 tooth basket Neil Spalding at Sigma has clutch packs in stock .....
Old 17-May-2006, 22:19   #3
Animal's Avatar
Cheers!
Old 17-May-2006, 22:23   #4
Animal's Avatar
Does a standard clutch pack fit in a slipper?
Old 17-May-2006, 22:30   #5
yes and no. the plates are the same but you may well need a couple od dished plates..............more importantly it needs the stack height built correctly! Was that done?
Old 17-May-2006, 22:43   #6
Animal's Avatar
No idea, I've only had the bike a few days and the clutch has started slipping. The previous owner hardly used the bike so he may not of noticed...
Old 17-May-2006, 23:11   #7
before you buy anything, might be worth getting it looked at............stripped cleaned greased and built properly....
Old 17-May-2006, 23:22   #8
Animal's Avatar
I was going to book into pro twins to see what they think, can you recommend anyone else who could have a look in the Surrey area?
Old 17-May-2006, 23:36   #9
you wont go far wrong with them........obviously itll cost. Is there no member down there with the kit to look, it aint a big job.
