Old 17-May-2006, 22:11   #1
marcusjames marcusjames is offline
Overheating on 998
Hi
Wonder if someone can help. Went for a great ride at the weekend although noticed that the temperature would shoot up to 120 whenever I stopped in traffic for longer than a few minutes. It dropped again immediately I rode off.
Should there be a fan cutting in ?
Marcus
Old 17-May-2006, 22:27   #2
Mine runs hot especially when stood waiting at traffic lights.
The fans are controlled by the ECU and one should come in before the other. But they do seem to come in a bit late as if somebody told the programmers the UK is a bit on the cold side.
Old 17-May-2006, 23:03   #3
jodycraw jodycraw is offline
Mood: good
i've got a 748 and had a problem with the fuses for the fan (only 1 on the 748) - the shop told me to switch off the engine if it went up to 100 degrees.....
Not sure what your problem may be - check the fuse for the fan as if that is blown then the fans won't come on!?
Old 18-May-2006, 11:19   #4
james81273 james81273 is offline
james81273's Avatar
Mood: twitching
try this its alot cheaper than a twin core rad Ker-ching!
http://www.evoluzione.net/evoluzione...sports_149.htm
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:30.
