Old 18-May-2006, 12:34   #1
tranquil_rage tranquil_rage is offline
Bikes: Ducati 900SSie
750SS Carbs & Dynojet
I'm going to have to strip my carbs as its ****ing fuel out of the overflow after I give it a hard blt adn then stop. I think its down to needle seating or the float control. Either way a good clean and overhaul should do the trick.
Now as I will have the *******s apart I thought it would be an excellent time to fit the dynojet kit. However I wont have replaced my exhausts by then. I will have a K&N filter.
I want to know if this will foul the engine not having an aftermarket exhaust system when paired with a K&N and a dynojet kit.
Old 18-May-2006, 13:29   #2
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
With a dynojet kit you often will have a variety of jets and needles which, you will select according to the set up you have and the reading your gas analyser gives....well, I did with my SV650s. So, it's not a case of will it foul or will it not foul. All pipes, all filters and all bikes are different so, it's unlikely that just fitting whatever they might suggest on the instructions will work. You still need to set the bike's fuelling properly for whatever other hardware is fitted to it.
I hope that's answered your question for you.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:25.
