Old 18-May-2006, 14:30   #1
mydogbitjesus mydogbitjesus is offline
mydogbitjesus's Avatar
breaking markers?
Hi,
Can anyone tell me how to set up breaking marker points for the corners when doing trackday's, so you can blast along and then break as late and with maximum force?
Cheers,
Pete.
Old 18-May-2006, 14:36   #2
Its a process of elimination!!! - pick a reasonable braking point, then adjust this as necessary each time you get to the corner. Your braking point is dependant upon how much you brake, how fast you are going, how good your brakes are, and how big your nuts are!!!
Trial and (limited) error.
Tim
Old 18-May-2006, 14:45   #3
Tim
This is going to sound a bit silly but ... make sure you pick something that isn't going to move.
People have done it!
Old 18-May-2006, 14:49   #4
domski's Avatar
It is rumoured that lots of top racers don't even use braking markers.
Do you use breaking markers on the road?
Hrmmm
Sometimes I use them and sometimes I don't, depends where it is etc.
How do you guage when you're 10 yards past something you're using as a marker? That's a bit random isn't it?
You could always wait until the marshals start running for cover
Old 18-May-2006, 14:54   #5
Mr_S Mr_S is offline
I bet they do, just not consciously.
Yes, and turn in markers, it's all part of the cornering plan.
Old 18-May-2006, 15:07   #6
domski's Avatar
Wayne Rainey didn't use them :P He did OK
Old 18-May-2006, 15:12   #7
You sure about that? I seem to remember him being coached by Keith Code ...
Old 18-May-2006, 15:20   #8
domski's Avatar
That's where I read it.
"The soft science of road racing motorcycles"
Rainey does the margin notes.
Old 18-May-2006, 18:14   #9
weeksy2 weeksy2 is offline
Like said above.... take the corner a little differently.... work out on the 1st session where your turn in point is, then work out where you need to brake to reach the turn in point at the best speed for you.
All braking markers will be different... but all turn in markers whould be pretty much the same. Basically you're picking something like a post... end of a fence etc etc... Once you're comfortable at that... move it up a fraction. e,g 1/2 a count after there... and progress.
In a lot of ways having the braking marker as your 'maximum' braking point is a little silly. You're going to end up scaring yourself time after time after time.. you'll end up not letting off the brakes and messing up the corner....
Brake so you are off the brakes 20m from the turn in point and work on increasing your corner entry speed.
You will gain a max of 0.1 second on braking but you could potentially gain a lot more by entering the corner 5mph quicker.
Old 18-May-2006, 18:25   #10
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
I don't use them either. I'm too busy looking where I want to go. I generally have a pretty good feeling when it's getting a bit late to brake.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:02.
