Old 20-May-2006, 11:12   #1
gossa gossa is offline
gossa's Avatar
dyno test results
Hi all, onto my second post already!
I have an 05 999s which I recently had into motorapido for valve timing and Ergal belt roller kit. The only other performance upgrade to the bike is the 54mm Termis which come with it. I've gone up two teeth at the rear and fitted an X ring chain (both Ducati Performance).
As part of the work it went on the dyno and an extra 6hp at the wheel was achieved. it's putting out 129 at the wheel.
Has anyone got a similar bike that has been tested to compare? Just curious.
Clive
Old 20-May-2006, 14:02   #2
dickieducati's Avatar
'03 999s pc111 54mm full system:
Old 20-May-2006, 14:41   #3
gossa's Avatar
Is that about 145 at the wheel?
Is that a before and after with the Power Commander?
Old 20-May-2006, 17:24   #4
that'll be a crank figure so less, say 8%, 135 at the wheel?
yes that was a before and after with the pc111 how does you torque compare to that?
andyb (999r) has a very similar curve set up at same place: jhp.
Old 20-May-2006, 17:25   #5
Stu748R Stu748R is offline
Mood: I've just ordered a new bike and its a ..
Dont forget that Moto Rapido's dyno is notorious for not reading as high as quite a few others.
Old 20-May-2006, 18:48   #6
gossa's Avatar
dickie, i'll dig the printout out to check the torque, the guys at motorapido said they were hoping for a tad more so just wanted to see if anyone had a similar bike to compare.
there was a bit of a flat spot around 6000 which was sorted by the work.
ta
Old 22-May-2006, 18:24   #7
bike mad bike mad is offline
bike mad's Avatar
so why is the 996 making more power than the 999?
ps good choice of pipe
Old 22-May-2006, 19:13   #8
barnsey barnsey is offline
How to they measure the power at the crank??? surely its only the rear wheel power that the dyno can measure so why bother quoting 'crank' horsepower?? guess the bike owner just wants to hear the biggest number for pub talk and posting on the forum!
one thing i know about dynos is they are all VERY different. +/- 15% is not unheard of.
Old 22-May-2006, 19:41   #9
thats just the name of the map. its a before and after set up with pc111 on a 999s
Old 22-May-2006, 22:38   #10
Brogins Brogins is offline
Brogins's Avatar
Mood: PENSO POSITIVO....SEMPRE!!
05 dyno 999 with shark
999 05 biposto standard with shark exaust, PCIII and filters...
Not bad... 131... Motorapido did the work as well.. sorting out the a flat spot at 4000 RPM setting the PCIII... love it now.
[Edited on 22-5-2006 by Brogins]
