Old 20-May-2006, 15:07   #1
Red-Duc Red-Duc is offline
Red-Duc's Avatar
What make do you use
Im just about to do an Oil,filter,plug, fuel filter and airfilter change on my sl any recomedations on makes for the above and should i stay clear of any particular products
Old 21-May-2006, 08:46   #2
Oil:
Synthetic - Mobil1 15W-50 Car spec, Shaazam! has spoken:
http://ducatisportingclub.com/contro...d.php?tid=6566
OilFilter: I prefare the K&N item as it has a nut built into the end for easy removal
Airfilter: K&N again, expensive but reusable with a cleaning / oiling kit both available from:
http://www.pdq1.com
or Hein Gerick / M&P etc.
Plugs: I've tried NGK and Platinum plugs and thought the Platinum plugs helped starting (a bit) but I'm not convinced the running is any smoother) - some peeps are saying try a different grade of plug for the rear cylinder as it runs hotter but I've not been down this road yet !!!
Fuel Filter - stick with Ducati OEM I think - following Dereks recommendation I'm moving mine to OUTSIDE of the fuel tank (not sure exactly where yet, mind) but I cant see the logic of having a replacable item - inside the fuel tank). PS - Newer style filter I was sold is metal bodied as opposed to the original plastic one inside the tank.
Cheers - Frank
Old 21-May-2006, 09:29   #3
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
Oil filter: Ducati
Fuel filter: Ducati
Air filter: K&N
Plugs: NGK Iridium
Oil: Any decent 15w-50 fully or semi-synth
This is in an 800ss.
Old 21-May-2006, 17:12   #4
Red-Duc's Avatar
My god Shaazam certainly goes into things
What ngk plug is suitable for a 900 superlight, the manual only states champion
As for oil I think that i will stick with a semi-synthetic, It seems that some people dont think the bike needs fully
Old 21-May-2006, 23:36   #5
http://www.sparkplugs.co.uk/pages/pr...plications.asp
Standard: DPR8EA-9
Copper: DCPR8E
Iridium: DCR8EIX
PS - ALL posts by Shaazam! are compulsory reading on the DSC
Old 23-May-2006, 19:58   #6
Red-Duc's Avatar
Im a bit confused about spark plugs
using the NGK site It converted the following
the standard plug is DPR8EA-9 converted to DPR8EIX-9
but the standard plug in the haynes book is Champion RH6HC which converts to DCR8EIX
So which would be best to use??
Also any ideas where I can get a k+n filter from online
cheers
Old 24-May-2006, 00:52   #7
aka.eric aka.eric is offline
K+N Air filter £47.61 Demon Tweeks,or direct from K+N.
Pipercross Air Filter £45.24 Demon Tweeks or direct Pipercross.
Personal preference Pipercross.
Old 24-May-2006, 01:33   #8
However, using the NGK website part finder:
http://www.ngk.co.uk/
It NOW recommends std plug: DCPR8E
or Iridium Plug: DCR8EIX
which is not how I remember it, to tell the truth. There did used to be some differences when cross-referencing from one manufacturer to another.
If all else is Ok i'd try a std plug first, the if you want to try an Iridium plug or some other in a little while you can always keep em as spares!
Good luck - Frank
Old 24-May-2006, 13:48   #9
Derek Derek is offline
Bikes: ST4s ABS
Derek's Avatar
Just to clear some confusion. With NGK the plugs the -9 indicates that the plug is pre-gapped to .9mm i.e. 35 thou.
The C in DCPR means it has a copper core
and the A in DPR8EA-9 means it has a "Special electrode" whatever that is.
IX means an Iridium centre electrode
So a DCPR8E is the same plug as a DPR8EA-9 but with a wider heat range due to the copper core and it has a standard gap of, I think, 0.6mm and something different about the electrode.
The IX versions are the same plugs with an iridium electrode.
So a DCPR8E or DCPR8EIX should be a suitable replacement for a DPR8EA-9 or DCPR8EIX-9 apart from the gap which you can increase if you wish.
Ducati recommends 0.6mm but the igntion system is quite capable of firing the 0.9mm gap which reduces the chance of plug fouling.
I think NGK have just updated their plug refernces to reflect the improved performance of their newer technologies.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:38.
