Old 07-May-2014, 21:37
coppersaucepipe coppersaucepipe is offline
Bikes: YZF750R, DD 'B' class monster #2
Compression
What should the compression be on a good class B bike? I've got 9 bar on the front and a smidge over 7 on the rear on the engine in the bike. My spare measured at a smidge over 9 on the front and 9.5 on the rear.
Old 07-May-2014, 22:56
7 bar is to low
where as 9 to 10 bar isn't bad
Old 08-May-2014, 08:27
milesaway's Avatar
milesaway milesaway is offline
Bikes: 900ss 600ss xr400
mine gives over 9 on both- is it the cyl you were pouring neat petrol down that's low? check yr valves first but if it's the flooded one you probably washed off oil and damaged rings/bore- shame its not front as 10 times easier to pull off and investigate
Old 08-May-2014, 12:19
It is the flooded rear cylinder. I'll drop the spare engine in for Anglesey and have the current engine apart on the bench I think. It hydrolic locked at one point, so I'm guessing I may have damaged something then if it wasn't already low.
Old 12-May-2014, 15:52
bally71's Avatar
Mood: Inquisitive cat
Measured mine yesterday
6 bar front
6.5 bar rear
LOL .. Think it's time I swapped that engine
Old 12-May-2014, 17:45
milesaway's Avatar
6 bar front
6.5 bar rear
worth checking valves first- if clearances are out enough can loose compression- if they are its as easy to pull off the heads then you can grind them in before you set clearances and can check state of bores and measure rings at the same time
Old 16-May-2014, 11:05
or its even easier to get miles to do it for you..
Old 16-May-2014, 22:00
milesaway's Avatar
tell you what matt- the money people seem to charge for doing such things i'm beginning to wonder if carpentry isn't the wrong business to be in!
  #9
Old 16-May-2014, 22:29
Its not what people are charging Miles it's the daft buggers paying the elevated prices. One could be busy working for nothing but sensible fees should apply.
  #10
Old 18-May-2014, 15:09
bally71's Avatar
cheers miles .. but I've planned to change the motor anyway
Nice fresh motor .. should be all up and running ready for Donington
Can't wait .. the old motor was only making 50 odd horses ... I won't be able to control the thing with an extra 10 ....
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:55.
