Race
MotoGP / WSB / BSB / Local racing.
*** WARNING*** May contain race results!!
Old 21-May-2006, 21:46   #1
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
I am clearly of a sick mind
I've been doing some work on my 800ss minitwin racer chassis now that I've pretty much finished with engine development - the usual stuff of removing everything not needed. This evening it was switch gear and all electrical ancillaries...then I thought about lopping off connectors/wiring to indicators, lights etc to save a bit of weight and remove complexity...
I got carried away and built a custom front loom instead, all heat-shrunk and spiral-wrapped.... saving the grand total total of about 1/4 of a lb
At least it's easier than going on a diet
.....and it works.
I suppose I should tackle the main loom now but, that's a bit more bothersome.
Old 21-May-2006, 21:58   #2
Carbon749's Avatar
Mood: I own a flame thrower
Or you could just make sure you go to the toilet before the race and that would shed about the same weight
Old 21-May-2006, 21:59   #3
I do normally...but that is nerves at work
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:42.
