Old 22-May-2006, 15:44   #1
dave996 dave996 is offline
dave996's Avatar
Mood: Fed up...
Tap and Die
Has anyone got a 12 x 1.25 tap and die set I could borrow plleeaasse. Tried to buy one over the weekend and couldn't
So if someone could help that would be great.
Dave
Old 22-May-2006, 16:53   #2
weeksy2 weeksy2 is offline
Crust or Skidlids mate... i can ask Crust to bring tonight if you'r going to Foxs's (if it's dry)
Old 22-May-2006, 16:57   #3
dave996's Avatar
Mood: Fed up...
Cheers mate. Can't make Fox's I'm on call tonight.
Any chance in getting one in the post?
Dave
Old 22-May-2006, 19:13   #4
Jasper Jasper is offline
Jasper's Avatar
these any good for you?
http://www.ducatisportingclub.com/xm...ge=1#pid328388
Old 22-May-2006, 19:31   #5
dave996's Avatar
Mood: Fed up...
Cheers Jasper, what it was was when I had my frame/swingarm powdercoated they forgot to cover the holes for the pinch bolts and I need to clean them out.
Thanks anyway
Dave
Old 22-May-2006, 22:32   #6
Sorry Dave, Haven't got a tap that size bit rare as ISO standard is M12 with a 1.75mm pitch, metric fine is with a 1.5mm pitch so 1.25mm is ultra fine pitch. Possibly the same as some spark plugs, maybe worth checking to see if a plug thread chasing tool will do the job.
Old 23-May-2006, 13:41   #7
doogalman's Avatar
Or make a tap with anbolt the same thread, cut some longitudional slots in the thread, to cut the paint away. Have got out of trouble by this method myself in the past.
Old 23-May-2006, 14:22   #8
checked and 12mm X 1.25mm pitch is the same as some spark plugs, but you would have to do it from the underside i suspect
Seeley do a tool
http://www.tooled-up.com/Product.asp...er-10-And-12mm
http://www.premiertools.co.uk/item2645.htm
http://www.spark-plugs.co.uk/pages/p...ance_tools.htm
http://www.toolsnstuff.co.uk/product...e 0ee868bd585
Old 23-May-2006, 14:27   #9
dave996's Avatar
Mood: Fed up...
Cheers for that Kev, it looks like it will be my best option.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:56.
