Old 25-May-2006, 18:11   #1
ducasa ducasa is offline
998/748R shower injectors removal
Hi Guys
I'm in the process of removing the airbox on my 998, problem is I cant get the shower injector bodies to detatch from the bell mouths.
It looked like a simple case of uncliping the plastic bodies, but although they all unclip there seems to be some resistance. Whats the secret?
I assume the 748R has the same setup
Old 26-May-2006, 08:00   #2
frazelli frazelli is offline
Mood: whatever!
Twist the bell mouths they should then come off allowing you to remove the airbox, they are only hand tight.
I can't remember whether they twist anti clockwise or clockwise!
Regards Frazelli
Old 26-May-2006, 09:15   #3
yep should just twist off and should be anti clockwise.
The 998 parts are slighly different than the 748R which also has a two piece airbox
Old 26-May-2006, 12:39   #4
Thanks skidlids
Checked out the parts manual, and came to same conclusion just like earlier dukes.
What about the fuel connector and the loom connectors to the injectors?
