Old 04-Jun-2006, 21:31   #1
minty70uk minty70uk is offline
Electrical Problems
Right guys the 916 is still not running! Had my new rectifier fitted on Friday by a dealer and the bike fired into life. However upon being switched off my dealer couldn't get it to start, he racked his brains and suspected the ECU was knackered! He removed the ECU and fitted a 916SPS one he had and immediately the bike ran as normal. Anyway again after turning the ignition off the bike failed to start again. However if the bike is turned on and off in under 10 seconds the bike will run excellent, anyway what this did confirm was that the ECU was not knackered..........massive sigh or relief! Anyway what he has got it down to is that when the bike is switched off after 10 seconds the engine management relay trips out and it takes removing the ECU to reset it. This I suspect and he does too is that there is a problem on the relay wiring somewhere. Anyway this was Friday at 3.30pm and all the guys from the dealer were booked on a 6pm ferry to IoM for the TT's hence the shop is shut for a week. Whilst I have every faith that he will resolve the problem I thought it might be worth a note on here just in case someone else has had the same problem as I still haven't rode the 916 this year. Any help would be appreciated PS Are all Ducatis like this?
Old 08-Jun-2006, 20:05   #2
No one help me with this? Currently an "R" here Biker without a Bike
Old 08-Jun-2006, 21:46   #3
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
Hello minty70uk
Maybe no help, Does the fuel pump prime when you turn the key?
but if you lift the seat you will see two black relays, maybe one is faulty,
Its been a while but I think, I am right in saying the front wiring ie fuel pump
runs through these relays to the ecu.
You should here them click (open and close) it could be they are not resetting themselves via the ecu.
It is not common for the ecu to packup, and as the bike has been running I would of thought all is ok there.
barring checking all fuses, and wiring to and from the rectifier, neutral switch, as I am guessing the bike was running before, your replacement part.
Is there an alarm/immobliser fitted?
sorry maybe of no help.
I am sure somebody will be along soon with other options.
hope you get things sorted soon
TopiToo
Old 09-Jun-2006, 23:04   #4
Thanks TopiToo any thoughts on this a really welcome and yes I shall pass it on to my dealer PS Its does have an alarm datatoll system3
Old 09-Jun-2006, 23:04   #5
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:14.
