Old 05-Jun-2006, 08:58   #1
weeksy2 weeksy2 is offline
Clutch slave cylinder... Options ?
Well every Tom Dick and Harry with a Ducati seems to have a lighter clutch than me... i assume i can go down the easy route of getting the bigger and better Slave....
So what do i go for and from where please chaps ?
Old 05-Jun-2006, 09:53   #2
Ray Ray is offline
Ray's Avatar
Steve,
Million and one places to get em from. I've had one yoyodyne from the USA, included some nice Ti fixings and one from Nelly at Cornerspeed.
Both worked well and reduced the effort required to operate the cutch.
Some many people do em, STM, MPL and loads of other peeps brand 'em.
Ray.
Old 05-Jun-2006, 10:16   #3
Cheers chap... will have a wee search.
Old 05-Jun-2006, 10:41   #4
http://www.tecmoto.co.uk/
under accessories
Old 05-Jun-2006, 10:47   #5
I beleieve Nelly is awaiting a new batch coming in, could all be ear-marked already of course - there is a pic on his website I believe.
MPL ones come with differing length push rod adapters (from memory) - otherwise Ray is spot on!
Frank
Old 05-Jun-2006, 12:58   #6
james81273 james81273 is offline
james81273's Avatar
Mood: twitching
Evoluzione oversize race style billet aluminium clutch slave cylinder
http://www.motorapido.co.uk/online%20shop.php
perfomance parts...then..clutch..then second page in...
got mine from moto rapido £109.99 with the bleeding kit.. nice and easy to fit and very quick service. And Blimey does it make traffic easier!
Old 05-Jun-2006, 13:06   #7
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
Hello weeksy2
Fitted a Cornerspeed one very trick bit of kit,
Just if you are going to fit one, pull the pushrod out and check is all ok.
Then maybe even check/clean the pushrod bearing, replace if need be.
As I had the bearings seize, locking the pushrod, and as a result distroying the piston inside the new master cylinder.
But maybe I am just lucky . . . . .
TopiToo
Old 05-Jun-2006, 13:11   #8
Hmmmm bike will be off there in winter for it's service... migght get that done at the same time....
thanks all.
Old 05-Jun-2006, 13:17   #9
Steve,
All the aftermarket slave cylinders do to achieve a lighter clutch lever is to increase the bore in the slave piston. Now, depending on the bore and stroke of your master cylinder (I think the 916 is 16 mm ???) it can only pump a given volume of hydraulic fluid. By definition, if the bore of the slave cylinder increases, then given the total amount of fluid that the master cylinder can pump into it the stroke that the piston can move is obviously less than the original slave.
Some of these slaves (at least STM ones) come in two bore sizes - 28 mm and 30 mm. I bought a 30 mm one for my ST and found that despite bleeding it until I was blue in the face, the standard master cylinder simply could not pump enough fluid into the 30 mm bore to move the slave cylinder far enough to completely disengage the clutch. I sold it to KeefyB who put it on his 999S without hassle because the 999S master pumps more fluid. I might have been fine with a 28 mm unit, but in the end I went for a standard uprated version (the one with the big torx looking thing).
You might also need a different clutch actuator rod as well. They changed to a longer rod in 2001 so if your bike is earlier than that it will either need a spacer to fit the slave (STM's come with one) or a longer rod. You need to be sure of your model years as well, although my bike was registered in 2001 it was made in late 2000 and had the shorter rod.
___________^
Old 05-Jun-2006, 14:52   #10
Excellent post Jools.... thanks fella.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:15.
