Old 05-Jun-2006, 08:43   #1
DAZZERS FE DAZZERS FE is offline
DAZZERS FE's Avatar
Mood: Need to get out on the 998
Clutch problems
Hi
could anyone tell me if a clutch from a 2005 749 would fit my 2004 998s FE.
I think the clutch would fit but I don't know if the plates would be the same, ie would the pressure/grip be good enough for the bigger motor or would it just slip.
Dazzer
Old 05-Jun-2006, 12:23   #2
DAZZERS FE's Avatar
Hi
Does anybody have any ideas
Dazzer
Old 05-Jun-2006, 14:35   #3
yeti yeti is offline
yeti's Avatar
Should fit ok. You might need to play about with plate sizes to get the right stack height - usually 38mm, but it is do-able. Only other thing to note is shaft size, the S MAY have a 25mm shaft in which case you may or may not need a spacer and a new nut. Hope this helps.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:06.
