Old 07-Jun-2006, 14:00   #1
RickyX RickyX is offline
RickyX's Avatar
Smile Race Fairing - QUIZ!
HISTORY
I recently bought a "race" fairing that had no cutouts for headlights.
Since I want to be able to use this on the road, I needed to make a circular cutout on LHS to line up with the dip beam headlight lens centreline.
PROBLEM
When the nose fairing is fitted over the lights, the centre of the headlight lens is no longer visible.
QUIZ
How did I accurately mark the centre of the headlight lens on the outside of the nose fairing?
PRIZE
Satisfaction that you can solve a technical problem !
Post your ideas below.....
Old 07-Jun-2006, 14:05   #2
Use an existing road fairing and place the race fairing inside - they should overlap?
Draw round the full hole of the headlight, which shows you exactly where the headlight is.
Now you can measure from the corners to centre the cut for your hole.
I did this with my DD bike fairings when marking up some cut-outs for it!
Old 07-Jun-2006, 14:11   #3
weeksy2 weeksy2 is offline
stick a piece of bluetack on your headlight in correct place....
dab tip with superglue.... then fit fairing....
it should then stick to inside
hopefully
Old 07-Jun-2006, 14:13   #4
hopefully
Yes, or a blob of paint.
Good thinking!
Old 07-Jun-2006, 14:25   #5
andys 900ss's Avatar
Hi Ricky,
My R1 has a race fairing and we used tracing paper to draw around the light unit and then traced that onto the race fairing. Carefully cut with a fret-saw and look how mine turned out!!! and we didnt have a road fairing to refer to either.
Andy
Old 07-Jun-2006, 14:27   #6
Turn the lghts on
Old 07-Jun-2006, 15:34   #7
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
Another offering...
Drill two small holes approx where the hole is going to be.
stick a bit of paper on the light and cut the paper to the right shape.
fit fairing.
mark dots through the drilled holes onto the paper.
remove fairing.
remove paper.
stick paper to the fairing lining up the holes you marked.
cut.
Old 07-Jun-2006, 16:53   #8
RickyX's Avatar
Remember that I said "How did I accurately mark the centre of the headlight lens on the outside of the nose fairing?"..in other words, I have already done it.
Nick is closest but still no cigar.........
METHOD
1. Remove fairing
2. Place "Workmate" in front of bike
3. Place DIY Store "Laser Leveller" on Workmate and aim it at the centre of the light.
4. Install fairing - caution not to bump into workmate!
5. Mark centre of light where laser dot projects onto fairing.
Hey presto - job done!!
I cut the hole by measuring the diameter of the len, then scribing a circle on the fairing (using an Art Shop "circle cutter"), then cut hole with my trusty old jigsaw.
Cheers,
RX
Old 07-Jun-2006, 17:01   #9
Heh, that's far too high tech!
Old 07-Jun-2006, 17:11   #10
NBs996's Avatar
Ah.. a very cunning plan.
But after carefully aligning the laser and marking the spot with the sharpest of pencils - I'd've used a hole-saw on the end of a ferkin' great Hilti to finish it off!
So much more fun
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:05.
