Old 07-Jun-2006, 21:36   #1
Andy C Andy C is offline
Question ss carbs
600ss carbs- BDST 38 B 156
900ss carbs- BDST 38 B 67
Apart from the jets/needles etc, is there any difference. They most certainly look the same.
Old 07-Jun-2006, 22:06   #2
phil_h phil_h is offline
phil_h's Avatar
Carb manufacturers tend to use a number added to the end of the 'generic' part code to indicate the build spec of the jets, slide, needle. Its therefor not surprising to see that the 900SS number is 'earlier' than the 600 which was first produced much later.
If you fit a dynojet kit, most of the spec differences will be lost
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:40.
