Old 12-Sep-2003, 18:54   #1
chief chief is offline
chief's Avatar
Mood: Either bemused or indifferent
996S they all do that
I know this is utter crap but my 996S with chip and 54mm pipes splutters when you give it loads and you kind of have to roll the throttle on not pin it. Hacketts say all the "S" models do that. Cannot see it my self anyone....anyone?
Old 12-Sep-2003, 18:56   #2
Nigel Booker Nigel Booker is offline
Bikes: Ducati 996R and MV Agusta F4 1000R
Nigel Booker's Avatar
My 996 bip did it until I fitted an ultimap chip.
Old 12-Sep-2003, 19:08   #3
Its not right.....
....its gotta be poor fueling;
If its always done it since the pipes and chip were fitted, is probably the chip, - go for a FIM Ultimap and get it setup for your bike. - or get a decent chip for 54mm open pipes.
If its only recently started then it may be blocked fuel filter or blocked air filter.....
Tim
Old 12-Sep-2003, 19:09   #4
Wadd Wadd is offline
I used to own a 996s with 54mm pipes and mine was fine apart from the odd popping from the silencers when on the over run.
Old 15-Sep-2003, 15:13   #5
chief's Avatar
Thanks for the info boys. I have thrown it back at Hackett's with an oil leak thrown in for good measure!
Old 16-Sep-2003, 08:53   #6
rcgbob44's Avatar
My 998s with 50mm temi`s and Dp ECU does that after a thrash, completely cuts out in fact. Then i have to waite for a minute or so before it will restart.????????????????????????
ps I`m told a lot of duke do this!
Old 16-Sep-2003, 09:23   #7
Have a read of Shazaam's response on this, as it offers a (possible!) cure:
http://ducatisportingclub.com/contro...d.php?tid=2767
Old 16-Sep-2003, 10:32   #8
rcgbob44's Avatar
Antonye
Have read the wise sage Shazams thought on the above but i know its a fueling problem and not a connector problem.
Methinks i will investigate further, thanks for the advice anyway. Take care.
Old 16-Sep-2003, 10:56   #9
From your description it sounds exactly the same, hence the reason I mentioned it, especially the "wait for a minute or so before it will restart" bit!!
Next time it happens, give Shazaam's trick a try and see if it works. Don't forget to let us know what happens...
Old 17-Sep-2003, 08:26   #10
Ivan 996S Ivan 996S is offline
996s
Cheif
Hacket is right they all do it. Its something to do with the second injector throwing to much fuel in. The way round this is to fit a FIM chip that only uses one injector or to fit a power commander to sort the fueling.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:08.
