Old 12-Jun-2006, 19:46   #1
iang iang is offline
iang's Avatar
Engine differences 749/999
Right, before someone says it I know 250cc !
I am considering the 57mm exhaust upgrade kit but it is made for the 999/999S. I have been informed that apart from the ecu the rest of the kit will fit the 749 fine, as long as it has the new swinging arm.
Does anyone know if the actual physical size of the engines differ or is it just the bore/stroke, just in case the 999 motor was taller or shorter than the 749 then the exhaust manifolds would not line up.
Old 12-Jun-2006, 19:49   #2
Did'nt Butch say that the 749R had shorter barrels?
Old 12-Jun-2006, 20:37   #3
Ducati Dealer
wilf's Avatar
The 57mm system will physically fit no problem, external differnces on the motors are so negligable that it will make no difference.
But unless you have the R variant of the 749 then the best performance gains are from the 54mm. it gives just about the same top end but the peak power is lower, so easier to get to and use.
Good luck and fit a PC3 or you'll have plenty of fuelling issues.
748RS race bike (well, 853 but who\'s counting!)
999S road bike,
www.motorapido.co.uk
Old 12-Jun-2006, 23:03   #4
Sharpy G Sharpy G is offline
Bikes: 749R 2004
Sharpy G's Avatar
whats in the conversion kit ?
cheers G
Old 12-Jun-2006, 23:22   #5
weeian weeian is offline
Mood: 2 for 1 mmm :)
dosnt posidon run the 57mm system on his 749s ? ? ?
/ian
Old 12-Jun-2006, 23:31   #6
iang's Avatar
This kit contains all the 57mm pipework to convert the assymetric system to a full system with the new flattened pipework and it also includes the rear part of the Termignoni box, carbon guard, race filters and a 999/999S ecu, all for £950, the best price that I have so far is £820 ( Motorapido ) but my local dealer will beat that when I go in.
Obviously the ecu will only fit the 999/999S but as they are well over £600 for the ecu alone someone will be interested in a non coded/unused race ecu for a quarter to a third of that price especially if they have a Leo Vinci or Racefit etc exhaust.
Old 12-Jun-2006, 23:54   #7
isnt the box different tho ? ?
/ian
Old 13-Jun-2006, 00:17   #8
sbwells sbwells is offline
sbwells's Avatar
Mood: Bring the noise!
/ian
Yeap that's why the kit appears to include a new end piece for the existing can with the correct sized inlet spigots
Old 13-Jun-2006, 08:55   #9
iang's Avatar
Yes, all the job entails is to drill out the existing rivets that hold the exit pipes on the back of the can then fit the new end piece and rivet it back in place with the new band that is included in the kit.
The 749R exhaust kit is nearly £3,000, doing it this way ( for myself ) will work out at about £1600 and I will have a new carbon guard, a pair of new race filters, a cat free link pipe and a new 999/999S ecu all to sell which will be worth at least £300, so much much cheaper and still a full 57mm system apart from the titanium end can which does not bother me in the slightest, there is no performance gain or visual difference with the titanium can and as for the weight difference would anyone really know any difference, plus the stainless version does not crack !
Old 13-Jun-2006, 10:39   #10
chillo chillo is offline
chillo's Avatar
£820?? i'll have one
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:10.
