Old 13-Jun-2006, 19:15   #1
Guido's Avatar
Windows Explorer in XP Error message still.
Hope someone can help me with this error I get every time I try to move, delete, copy, rename, whatever a sub directory in Windows Explorer.
Appears straight away upon doing the above mentioned actions and is driving me mad. let alone stopping my workflow.
Also appears when I try to empty my waste basket (which contains sub directories deleted from my drive thru 3rd party image software).
Searched Microsoft Support but that's about as much use as a chocolate fireguard....I've only found that it 'MAY' be a registry related fault...
If any other info is needed then please ask but that's about it really.
Thanks again, Guy
Old 13-Jun-2006, 19:43   #2
Sorry Guy - searched for sometime but these ar ethe only similar things I found:
http://www.annoyances.org/exec/forum/winxp/t1045537529
http://www.annoyances.org/exec/forum/winxp/t1095806673
Good luck - Frank
Old 13-Jun-2006, 20:50   #3
Murray Mint's Avatar
Try applying service pack 2.
Old 13-Jun-2006, 21:06   #4
Guido's Avatar
I have SP2 installed so am at a bit of a loss as to what this can be. I have read of IE6 issues with SP2 but my problems are with Windows Explorer not Internet Explorer.
Old 13-Jun-2006, 22:00   #5
Loz Loz is offline
Loz's Avatar
Not sure I can help, Guy, but is it a particular sub-folder in Windows that you cannot copy or is it every sub-folder? Can you restore files from the waste basket?
If you use Command Prompt, can you re-name the affected sub-folders using DOS commands?
I know I've seen this error message myself, usually when closing down XP, but it never stopped me doing anything and hasn't appeared in a long while now.
Sorry, groping here ...
Old 14-Jun-2006, 08:53   #6
guest1 guest1 is offline
There is an application available from microsoft that checks your RAM availability and the condition of the RAM. I don't have the link here but I'll try and post it tonight.
You could try searching on this site (doesn't always appear on google searches):
http://www.wopr.com/
Old 14-Jun-2006, 21:32   #7
Here's the memory checker I coluldn't remember earlier on:-
http://oca.microsoft.com/en/windiag.asp
could be a memory problem.
Old 15-Jun-2006, 07:14   #8
Guido's Avatar
Thanks Alan & Ozz,
Will give that diagnostic thingy a try first.............
The problem is will all directories Ozz. Not tried a restore from my Waste Basket.....The fault will not let me empty my waste basket of any sub-directories in there either.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:20.
