Old 14-Jun-2006, 19:51   #1
Col996s Col996s is offline
Bikes: 996S
Col996s's Avatar
Computer question
My daughter has managed somehow to move the bar which is normally at the bottom of the screen to the left hand side. How do I restore it to the bottom? I'm sure in the past I've dragged it down but doesn't seem to want to work today.
It is Windows XP home edition.
Old 14-Jun-2006, 20:00   #2
Try a right-click with the mouse, when its over the bar (Taskbar) - there will be an option that says "lock the Taskbar" - if its ticked - it needs 'unticking'.
Select this - then you should be able to drag it down to the bottom as normal.
Frank
Old 14-Jun-2006, 20:26   #3
Bikes: 996S
Col996s's Avatar
Tried this Frank. It's not locked. Dragging it just increases the width of it.
Old 14-Jun-2006, 20:32   #4
Strange - I've just moved it in my XP home and back again by simply dragging from the centre of the taskbar, down to the base of the screen.
Perhaps - close all other task and maybe try it straight after a reboot.
Old 14-Jun-2006, 20:38   #5
Bikes: 996S
Col996s's Avatar
Thanks Frank. I was not doing it from the centre but trying to drag the edge.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:18.
