Old 17-Jun-2006, 12:48   #1
wato39 wato39 is offline
Mood: Saving
Coolant leak
I've got a water leak from the header tank area of my bike that drips down onto the back of tha rad , i can't see a lot as its pretty congested around there , is it much of a job to get it off ? And is there anything around that area that is prone to leaking ?
Old 17-Jun-2006, 14:38   #2
doogalman's Avatar
I had that once. Never replaced the tank because it only happened the once and never found exactly where the coolant leaked from(may have just been the cap). never happened since. this was 2 years ago. Apparently the header tanks have been known to split. I bought one of ebay as a spare for a fiver just in case.
Old 17-Jun-2006, 21:02   #3
keefer keefer is offline
keefer's Avatar
the actual header tanks themselves are prone to splitting down the seam
its not to bad to get at.
a good morning or afternoon spare should do the trick.
there about 25-30 new so don't pay over the odds on flea bay
Old 17-Jun-2006, 21:06   #4
Dibble
yep, as Keefer says, they split on the seam which runs horizontally around it, takes about an hour to change .. tank off, belmouths out, airbox up, then move the ignition barrel out the way, undo the hoses and lift out.
Pop new one in and put it back together ....
I paid £18 (i think)for mine from JHP who posted it out, just call Dave on parts.
Old 18-Jun-2006, 10:58   #5
Mood: Saving
Thanks for the help everyone .
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:13.
