Old 18-Jun-2006, 18:27   #1
9rrr 9rrr is offline
Exclamation Torque setting
Hi all. What is the torque setting in Nmetres for the Clutch nut on the 996r Im running a bucci slipper and want to grease the ball bearings at the back. Also what size socket will I need. Thanks again Ian.
Old 18-Jun-2006, 20:33   #2
Just wanted to hunt through the files I have.
Std 996 manual says for "Clutch drum nut ?" 186 Nm with a tolerance of +/- 5%.
Nice touch that it lists sizes as well - 20mm apparently.
Not sure if a 996r will be different mind - NELLY !!!!
Cheers - Frank
Old 18-Jun-2006, 21:02   #3
Torque setting
Thanks Frank
Old 18-Jun-2006, 21:11   #4
No worries...
'Something' might be available from here:
http://www.duc.nu/manuals/
nudge, nudge...
F
Old 18-Jun-2006, 21:12   #5
sadly the o so elite 996r has the same size clutch nut as all the other meaningless models.........and 186Nm..........
Originally Posted by Iconic944ss
No worries...
nudge, nudge...
F
Old 18-Jun-2006, 22:26   #6
Greasy balls
How often should the ball bearings be greased on the Bucci slipper clutch.
Old 18-Jun-2006, 22:43   #7
When they need it.....its as unclear as that really! As you use it youl get to know!
Old 18-Jun-2006, 22:49   #8
Andy, what would you recommend. HELP.
Old 18-Jun-2006, 23:47   #9
polarexpress polarexpress is offline
polarexpress's Avatar
Mood: Impatiently awaiting parts!
You'll know it's time to grease it when it no longer operates as expected. For instance, you might find that you have to blip the throttle for it to re-engage once you've released the clutch lever whereas normal operation would dictate a gradual re-engagement without any extra throttle action on your part.
Old 19-Jun-2006, 00:00   #10
Talking torque settings
thanks vey much.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:15.
