Old 18-Jun-2006, 18:35   #1
Carbon749's Avatar
Mood: I own a flame thrower
749r running rough and dying - can you work it out
OK, my 749 was being a bitch this morning. I've cured it now, but, can you work out what was wrong.
Yesterday I had the side fairings off, fixed the contact on the left fairing panel for the alarm. Played around with the neutral switch connector on the back of the engine as it was loose. Had the tank and seat unit off. Set my mirrors up. Set my rear sets up. Fitted an ally pressure plate. All body work back on and basically gave the bike a good all over clean and polish ... no water used.
This morning I start the bike, ride it up the drive and leave it out front ... all OK. Turn the engine off and go to fetch my jacket and lid. Start the bike up and it ticks over nicely.
Get on the bike, flick the stand up, blip the engine and it dies now will not start for anything.
Get off, leave it for 2 mins and it starts first touch. Get back on, flick the stand up, blip the throttle and the bike just dies
Get off, leave it 2 mins and it starts. Get back on and hold the throttle at 3,000rpm, pull the clutch in and it dies
This carries on for about another 3 or 4 attempts, various combinations of clutch in, stand up, in gear and out of gear. No matter what I do the bike will start and tick over OK, but, dies as soon as I want to pull away.
Can you guess what it was
Old 18-Jun-2006, 18:37   #2
neutral switch...............something you did with the connector.........
Old 18-Jun-2006, 18:58   #3
Brent Brent is offline
Brent's Avatar
Partial fuel blockage, or blocked tank breather?
Old 18-Jun-2006, 19:07   #4
Carbon749's Avatar
I thought that, but, No.
Old 18-Jun-2006, 19:08   #5
Carbon749's Avatar
Very close
Old 18-Jun-2006, 19:09   #6
madmav madmav is offline
Bikes: 1098
madmav's Avatar
Mood: Chilled
neutral light wire /connector !
Old 18-Jun-2006, 19:11   #7
Bikes: 1098
madmav's Avatar
Mood: Chilled
Talking
or fogot to wire fuel pump back up!
Old 18-Jun-2006, 19:17   #8
Carbon749's Avatar
Nope, bike would start and tick over.
Old 18-Jun-2006, 19:19   #9
Carbon749's Avatar
Here's a hint.
Bike would start up and tick over fine when I stood at the side of it. I then get on and stand it upright ready to pull off and it dies.
Old 18-Jun-2006, 19:24   #10
Bikes: 1098
madmav's Avatar
Mood: Chilled
connector block under seat unit?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:37.
