Old 20-Jun-2006, 01:42   #1
djb djb is offline
djb's Avatar
Unhappy Fuel warning light embarassment!!
Lurvly run at the weekend 'cruising' past the tin boxes, down to the roundabout, knee out, pad down, oooh must look like Loris, splutter, splutter, conk....out of fuel. No warning!
Mighty red face as they all pass me pushing me wheels up the hill to the nearest petrol station!
Warning lights packed in - anyone any thoughts on the cause - relay maybe or fuse? From my very limited understanding of electrical diagrams doesn't seem to be on a separate fuse line?
Help appreciated.
D
Old 20-Jun-2006, 06:25   #2
DaveB916
You have checked the bulb? I assume so but you do not mention it.
Then if you find the connector at the tank you should be able to bridge out the appropriate pins to 'make the circuit' and test the sender unit?
A quick look on the 'Haynes' looks like light blue and dark blue with black marking wires, light blue being a fused feed and dark blue then off to fuel warning bulb, but just to confuse matters this changes to brown and white in harness before bulb.
The fuel light is fused along with the neutral light and oil pressure light so if those are working the fuse is ok.
So I reckon short out light blue and dark blue at plug and see if light comes on if so then sender at fault, if not trace the wire to where blue becomes brown/white and look for bad joint.
Hope that helps?
Any mishaps fuse No. 4.
Old 20-Jun-2006, 08:03   #3
jeff st4s jeff st4s is offline
jeff st4s's Avatar
Mood: Looking for a one way ticket to the 'Ring.
Cannot offer any technical advice, but feel sorry for the long lonley push up the hill.
Old 20-Jun-2006, 23:46   #4
djb djb is offline
djb's Avatar
Ta Dave. Yep bulb seems fine. Will try as suggested.
Jeff, yeah, I'm still bl**dy recovering!!
Thanks guys
D
Old 21-Jun-2006, 01:26   #5
nine98 nine98 is offline
I had the same embarassment on way back to work from lunch once.
Ended up being the sender unit in the tank .
The worst thing about that is that im a mechanic and I had to call for road sevice to get some fuel .
lol
Old 21-Jun-2006, 07:37   #6
ath748 ath748 is offline
ath748's Avatar
Mood: Missing my Flash...
When you fill up with petrol, reset your trip to 0000. When it gets to around 100, look for a station. Never need to rely on the fuel warning "test" light bulb!!
I'm sure you all do this already though.
Old 21-Jun-2006, 07:56   #7
paranoid paranoid is offline
paranoid's Avatar
how many miles do you have left once the light comes on ?
Old 21-Jun-2006, 10:07   #8
ath748's Avatar
There's another long thread on this topic, do a search....
Old 21-Jun-2006, 21:21   #9
Mark32 Mark32 is offline
In the good old days there was always the reserve tap................
If anyone finds the post with the answer to how long you can go once the light comes on can they post the answer.
Mark
Old 21-Jun-2006, 22:29   #10
lol
Welcome to the message board nine98
Now get the beers in! I'm never one to miss an opportunity ...
