Old 20-Jun-2006, 13:32   #1
spinoli1 spinoli1 is offline
Bikes: 998Bip
Mood: Carbonara
Side Stand
I wonder if anyone can help?
I have removed the small side stand switch sub-loom so that the motor will run with the stand stand down.
Whilst I've got away with it for a couple of years, it is only a matter of time 'til I start the bike in gear and it all goes crunch onto its side.
Now, I seem to remember that the is a simple mod to bridge a couple of wires that will result in the bike not starting when it is in gear (but with the stand down).
Anyone got any clues? (Be gentle, you're dealing with an electrical baboon here).
Spin (fizz, pop -- what's that smell?)
Old 20-Jun-2006, 14:02   #2
polarexpress polarexpress is offline
polarexpress's Avatar
Mood: Impatiently awaiting parts!
You'll be able to get a so called kickstand bypass wire from motowheels.com.
Go to their webpages (http://www.motowheels.com/) and search for kickstand bypass.
Good luck!
Old 20-Jun-2006, 14:42   #3
Ray Ray is offline
Ray's Avatar
You can make one up yerself for about 50p in bits but it won't look as nice and one with the proper connectors on.
Did a DIY job on my 998 ages ago with the intention of fitting the "proper thing" I bought off Nelly but so far i just haven't got round to it!
Somewhere on here, probabaly in the archives are the instructions on how to do the DIY job but if you are clueless with a soldering iron or making secure elctrical connections I'd go for the plug in option with the proper connectors, about £25 IIRC.
Whichever option you go for the bike will run with the sidstand down but as soon as you select a gear with the sidestand down , i.e the neutral light goes out the engine cuts. Runs and rides as normal with the sidestand up.
Ray.
Old 22-Jun-2006, 09:22   #4
Bikes: 998Bip
Mood: Carbonara
Many thanks for your answers Guys.
I’m not inclined to the buy kit, when a simple mod can achieve the same results for zero cost.
So I’ll lay into the bike with my Fisher Price adjustable spanner, carpet shears and blow torch – should be sorted in no time.
Don’t worry – I am actually reasonably competent in the work shop, an will do a nice neat job. Now, where's that freezer knife..........
Spin
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:14.
