Old 21-Jun-2006, 20:21   #1
sye73 sye73 is offline
748R rear wheel
Could anyone suggest why the rear wheel on my 748R has almost zero 'free-wheel' ? I noticed that whilst it was on a paddock stand and I happened to spin the wheel, not only was it tight, but wouldn't maintain any momentum at all. The chain is correctly tightened and nothing else seems amiss....Any ides ? Some kind of dry bearing maybe ?
Old 21-Jun-2006, 20:24   #2
binding rear brake? chain too tight?
Old 21-Jun-2006, 20:27   #3
Does the paddock stand shaft rotate on a bearing??, if not that will be the problem as the rear wheel won`t be able to rotate freely.
Chris.
Old 21-Jun-2006, 20:37   #4
thanks guys.....
The chain is fine, and the brake seems to work as it should. I'll check the paddock stand.......
Old 21-Jun-2006, 20:52   #5
good point - use the sidestand and tip it over onto the stand and front wheel so that the rear wheel is off the deck - give it a spin then
Old 21-Jun-2006, 21:08   #6
Bungi Bungi is offline
U may want to get a friend to help you do this if you havent done it before, saves dropping your baby
Old 21-Jun-2006, 22:29   #7
my vote is paddock stand...caught me out the same way..also careful if lubing and running on the stand (spiining the wheel) coz they work their way off! almost done that too TUT
Old 27-Jun-2006, 22:44   #8
thanks for your help on this..... It was the pesky paddock stand !
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:04.
