Old 22-Jun-2006, 09:48   #1
ali ali is offline
ali's Avatar
Mood: Damp
Question How to revive an engine that's been in the sea?!
Pretty much as the title says....
My brother found a reasonably new outboard motor in the shore-break and is looking to get it going. It's doubtful whether it's been turned over since it fell off whatever boat if fell off, but I'd still assume that it's full of water.
As somebody will probably reclaim it he doesn't want to spend any money getting it going, so what's the best bet for getting it up and running without trashing the engine?
Cheers,
Ali
Old 22-Jun-2006, 10:05   #2
Fordie Fordie is offline
Regional Organiser - BHCN
Fordie's Avatar
Mood: Raring to Ride
Place mouth over exhaust and blow five times looking for either a swelling fuel tank or salty fluid emitting from differant orofices. Failing that remove sparking plug and shake to living daylights out of the thing, put it back on another boat then ring the AA. Hope this helps (I'm sure it wont) 4D
Old 22-Jun-2006, 10:32   #3
ali ali is offline
ali's Avatar
Mood: Damp
Always full of great ideas 4D!!
And I'm not placing my mouth over any orifices....
Old 22-Jun-2006, 11:11   #4
Tonio600 Tonio600 is offline
Tonio600's Avatar
Mood: What a wonderful world.
errr.... sometimes you shou...
no sorry didn't write anything, I'm off before that topic gets deleted because of the insanity I may write
Old 22-Jun-2006, 11:11   #5
Loz Loz is offline
Loz's Avatar
Place the engine over a heater, turn it over very slowly (don't try running it) to drive the moisture from it. Keep turming over at intervals. As already suggested, spark plug out and then WD40 down the barrel.
Don't use your mouth, especially if you do get it running. Cheers.
Old 22-Jun-2006, 11:19   #6
ali ali is offline
ali's Avatar
Mood: Damp
Thanks Loz, finally a solution that doesn't require me giving 'oral pleasure' to the bloody thing!
Old 22-Jun-2006, 11:46   #7
Murray Mint's Avatar
What make of engine is it, have you thought of looking at the manufactures web site or users forums for this type of information?
Murray
Old 22-Jun-2006, 11:57   #8
swannymere's Avatar
Mood: High as a kite!
I was under the impression that anything abandoned or lost at sea becomes salvage and therefore free to anyone who salvages it.Of course i may be mistaken.
Old 22-Jun-2006, 11:58   #9
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
It's not so much the water as the salt you need to get rid of quick take plug out strip carb turn engine over afew times then tip some wd or parafin diesel down inlet port & turn the engine over afew more times the tip some clean petrol in & repeat, rebuild & start with x fingers.
Old 22-Jun-2006, 11:59   #10
Simon Reed's Avatar
Mood: Cool as **** !
Strip it !,its the only way,& re-new all gaskets,it cost you nothing after all !
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:06.
