Old 22-Jun-2006, 11:04   #1
LeeeeeeL LeeeeeeL is offline
Mood: Regretfully watching the weather again
Powder Coating
After seeing some pictures of black wheels with the grey frames anyone have any recommendations and/or idea of price to have 749 wheels black powder coated.
Old 22-Jun-2006, 11:27   #2
Had my frame done on the SS and it was £95 + VAT
I think they quoted wheels at about £40 each, but don't forget that you need to remove the bearings from them before getting them done, so factor in the cost of a new set of bearings (and fitting) to the overall cost.
I'm tempted to have my wheels painted black (as I can probably get them done free) rather than powder coated. You don't need to remove the bearings as they mask them off, so might be a cheaper / easier solution?
Old 22-Jun-2006, 12:53   #3
I take it the overall effect of the wheel painting is almost as good then ?
Old 22-Jun-2006, 13:02   #4
Yes, if done right. You'd want them stripped back and prepared well, just like any paint.
When powder coating they just leave it in an acid bath overnight to strip all the **** off it, then coat it - hence the need to remove all bearings and bearing surfaces. Headraces need to be pressed in, which is a pain to do if you don't have the right equipment or you end up paying more!
Old 22-Jun-2006, 13:19   #5
keefer keefer is offline
keefer's Avatar
any items I have had sprayed or coated have been bead blasted not dipped
head races on the 916 model bikes just unbolt and come away as a sleeve.
not sure about the 999 series bikes. depends if the steering head is adjustable or not I suppose
Old 22-Jun-2006, 16:49   #6
Wave Wave is offline
Wave's Avatar
I do like the Black wheels, the swingarm isnt too bad.
But it was the previous owner than done this.
