Old 22-Jun-2006, 10:47   #1
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
drilling bodywork
Hello
I bought a nose cone on fleebay, but needs drilling for
screen/mirrors.
Anybody done such a thing?
Is it best to start with mirror holes?
regards
TopiToo
Old 22-Jun-2006, 11:16   #2
rcgbob44's Avatar
Smile
It doesn`t really matter where you start providing you have all the holes correctly marked out. Start of using a small pilot drill and let the drill do the cutting ie don`t press hard to go thru` the material your cutting.
After you have drilled your pilot holes, and thay all line up, use a larger drill if need be, and go up in several sizes untill you get to the desired size.
I would suggest you use masking tape to mark the holes and this should stop the drill from "wandering" all over the place when you start of.
Good luck and don`t use the hammer action!!!!!!!
Things of beauty: Ducati 998s Mono: BSA DBD34: Vincent Black Shadow: Manx Norton: 1983 Laverda Jota: Matchles G50: Me!
Old 22-Jun-2006, 11:23   #3
Go from the outside in too - the material tends to lift as the drill breaks through, so you get a ragged edge on the exit holes. Going outside inwards means you won't see them.
Old 22-Jun-2006, 16:50   #4
Big Al Big Al is offline
All of the above but I use a hand drill for drilling any bodywork.
Old 22-Jun-2006, 17:36   #5
Bikes: 748ish . .
Ohhhhhhh!!!!
thanks for the advice will have a bash at the weekend
TopiToo
Old 22-Jun-2006, 18:05   #6
Loz Loz is offline
Loz's Avatar
Originally Posted by TopiToo
Ohhhhhhh!!!!
... will have a bash at the weekend
TopiToo
No, no, no! Not the hammer action, he said!
Old 22-Jun-2006, 20:33   #7
RickyX RickyX is offline
RickyX's Avatar
I have recently fitted a complete set of bodywork. I agree with the advice given earlier.
I would fit the screen to the fairing first and then put the fairing on the bike and mark the mirror holes etc. The screen holds the "ears" of the fairing at the correct distance apart - if you drilled the mirror holes without the screen fitted the screen might not fit.
Be patient and don't rush it - as if you were having sex or drinking a nice Rioja........
RX
Old 22-Jun-2006, 20:52   #8
Loz Loz is offline
Loz's Avatar
Thanks for that advice, Ricky. I have a c/f nose cone that I am saving for when I feel confident enough to try to fit it. It's this sort of hint that can make all the difference between a successful job and my usual efforts!
Old 22-Jun-2006, 21:40   #9
You will find that using a stepped drill is far easier and causes less damage to the fairing as it is not trying to pull itself through the panel like a standard jobber drill does.
Something like this.
http://www.tooled-up.com/Product.asp...eferrer=NexTag
Chris.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:37.
