Old 27-Jun-2014, 00:33   #1
pguenet pguenet is offline
FS - 996 RS / 998 RS race and performance parts
Genuine 998 RS airtubes
Good condition, one tiny crack on one
That's the slide in airfilter version which are very hard to find
Looking for £400
Complete Big Hub Mag race swingarm
As per pictures.
Longer race swingarm inclusive of big race hub, RS axle, sprocket assembly, nuts, chain rubbers, chain guard (not in pictures), brake disc, chain. I can give the rocker and ride adjuster but those are road items.
Condition is average as you can see in the picture but can be improved with some TLC
Please note that the spider brake disc assy has some play in it and would probably need to be changed. I may as one or know somebody that can make this item.
I would be looking for £1,350 for this set up.
+ £250 for the caliper hanger and the AP caliper.
Alternatively I can supply a Brembo race rear caliper at additional cost.
Old 27-Jun-2014, 00:33   #2
Ohlins R+T forks with JHP bottoms
Ohlins R+T forks with JHP radial bottoms for race calipers (108 mm)
Forks are the standard 53/56mm outters. So will fit yokes.
The road spindle will fit as long as the blue spacer is machined out to remove the thread.
Alternatively I can recommend somebody to make a custom spindle in Ti or else.
Forks are in great condition but need a service & change of seals
Forks have outer reservoirs and very trick billet mudguard mounts
Looking for £1500 with a service / £1350 for quick sale.
I can supply additionally - widetrack adjustable yokes and spacers to fit those forks
Radial monobloc race calipers that fit the forks.
60 mm PROMOTIVE system for 996 R / 998
Full system in great condition.
Needs a clean. comes complete with the manifolds that are not in picture.
No usual dent behind the footrest, the pipes are nice and no dent.
I will take better pictures at weekedn but please enquire if interested.
Looking for £1500
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:00.
