Old 25-Jun-2006, 18:49   #1
Olly Olly is offline
Mood: Not sure why I'm registered here any more...
750SS cutting out
Hi all,
Just bought my first Ducati, a 91 750SS. 16k miles, recently serviced, cheap! Collected it yesterday, and planning to use it mainly as a track toy.
Took it out for a first spin this afternoon - mostly good, starts and idles easily, clutch is smooth, gearbox good, revs cleanly throughout the range, handles cleanly, brakes fine. Cosmetically scruffy, but it'll clean up
One small problem, however. Two or three times when the engine was getting hotter, it started cutting out - felt like it was running out of petrol, didn't want to rev. Slowed it down, let it cool a bit, and all was fine again.
What could be causing this? What should I be looking at? (At this point I should mention that I am mechanically 'amateur', so small words, please!)
Cheers.
Old 25-Jun-2006, 21:12   #2
Dave G Dave G is offline
Dave G's Avatar
I sure I read something like this where the fuel was evaporating inside the carbs or something,but that doesnt seem likely,could it be **** in your fuel?
I'm afraid I dont get to use mine enough to have encountered any similar problems.
Oh, and have a look here for some local help and meet ups.
http://www.ducati-upnorth.com/forum/index.php
Maybe see you around sometime on my 'cosmetically scruffy' SS750
Old 25-Jun-2006, 21:21   #3
Herb Herb is offline
Check the fuel tank breather. I know some people have had problems with this. When you get the symptoms open the fuel cap and see if this cures it.
Also make sure the fuel lines under the tank are not pinched.
Old 25-Jun-2006, 21:43   #4
monstermob 998's Avatar
maybe the plugs overheating-- check you have the correct grade/gaps etc..a lean mixture may make the bike run hot and then the plugs would suffer
maybe the fuel filter may want changing- otherwise what daveg and herb suggests
welcome to the site lots of SS fans on here-i'm sure frank will be along soon!!
has it got a oil cooler fitted????
i'll have a red bull and lemonade cheers
Old 27-Jun-2006, 16:40   #5
Bingo. Breather hose was kinked, under the frame. Easy when you know where to look....
New tyres and chainset happening as I type, should be all set for the weekend
Old 27-Jun-2006, 17:11   #6
Hello oh short one Welcome to the fold - ( i remember speedos )
Old 27-Jun-2006, 17:26   #7
Kinda hard to forget, huh?
Old 27-Jun-2006, 17:32   #8
Its still pinned to my bedroom wall
Enjoy your new ride. Hows Scotland treating you ?
Old 27-Jun-2006, 19:22   #9
Scotland's good. Best roads in the world.
Shame I keep meeting up with these Northern Monkeys, mind you...
Old 27-Jun-2006, 23:28   #10
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
Hasn't anyone told you? Ummmmmm....we keep trying to get rid of you.
2 cylinders are all you need but, 3 is a fine compromise
www.twpd.co.uk
www.twpdracing.com
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:46.
