Old 28-Jun-2006, 08:50   #1
dst1 dst1 is offline
dst1's Avatar
Mood: thrash the bitch
Unhappy 916 strange starting problem
My 916 has developed a slight problem.....After a ride out it will not start of the button, only bump starting will get it going.
The next day the starter button will work again.
Any ideas...starter motor relay ???
Old 28-Jun-2006, 09:21   #2
weeksy2 weeksy2 is offline
Bit confused....
so before a ride out... e.g when it's been in the garage, does it work OK ?
Old 28-Jun-2006, 09:21   #3
Sounds very much like it. Could be that the relay connectors are a bit corroded and marginal, so that any vibration or heat causes the relay not to work, or it could be the relay itself is intermittent...
___________^
Old 28-Jun-2006, 11:58   #4
Before you replace the solenoid, check the small white connector that pushes into the back of it. These are notoriuos for playing up and exhibit the symptoms you have.
You can close the terminals in it a little with a small screwdriver or such like. so they grip a little better on the pins in the solenoid. When you refit it, pass a small cable tie between the two wires and around the solenoid to hold it in place.
Old 28-Jun-2006, 12:27   #5
dst1's Avatar
Many thanks Gentlemen, top blokes as always
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:05.
