Old 03-Jul-2006, 02:33   #1
rubberduci rubberduci is offline
Mood: mellow
Question 748 stalling at idle?
I am a new Ducati owner and looking for advice, I was out riding today and while sitting at stop lights the bikes idle starts to drop alittle then just cuts out. Restarts fine but does the same thing unless i give it some throttle?
The idle was set at about 1200-1300 rmps, I have since increased the idle a little to help stop this. Might there be a simple or common solution to this problem?
Any input would be greatly appreciated.
Old 03-Jul-2006, 11:55   #2
Harv748 Harv748 is offline
Harv748's Avatar
Without knowing anything about the bike its hard to tell really.
A well set-up standard or slighty modified bike will run sweet as a nut all day long.
My SP is a bit funny at tick-over know, but thats because it has a few mods, and is quite a 'characteristic' engine anyhow.
I would suggest you look at the basic fueling/mapping of your bike.
Does it have standard cans/chip/air filters etc.
If it does then it should run at all revs no problem.
If not then it may need setting up properly by a specialist in your area.
Throttle position sensor also springs to mind...although not to sure if that would give you the symptoms you describe?
Old 03-Jul-2006, 19:06   #3
Mood: mellow
Thanks Harv748....Well as for the mods on my bike as far as i know it was a stock bike until i put some termignoni slip ons, I have only owned the bike for 3weeks now and i am still getting familiar with the bike.
Thanks again for the input
Old 04-Jul-2006, 00:11   #4
Paul748bp Paul748bp is offline
Paul748bp's Avatar
id say get ur injectors checked get them balanced it should tick over happry at 1200 rpm
Old 04-Jul-2006, 07:45   #5
Did you change the chip when you put the termi`s on???, if not you should do it as soon as possible
Give Neil a ring & he will sort you out with what you need http://www.cornerspeed.co.uk/
Chris.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:15.
